Thread: Truck problems
    Jan 2005
    Jones, Michigan
    1,821
    Truck problems
    Hey guys i got a 93 f-150 with a 300 C.I.D 4.9L straight 6. today i was cruisin down the road and it started ticking a little bit, i wasnt sure if it was the motor or a screw in the tire so i reved it up. When i reved it up the oil pressure on the factory gauge went all the way towards the Low side, when i let it idle it's right where it needs to be. I came home, checked the oil and it needed a little so i did that and tried again. It still loses all pressure when i rev it up according to the factory gauge. Any ideas on what this is? we are assuming its the oil pump, maybe the screen on the oil pump, or i just seen a website that suggested main bearings ? thanks guys
    Kevin
    - Chick McGee
    -1985 250sx
    - 1986 atc310R drag bike
    - 1981 110 chopper.
    - 1985/6 350x
    - 2-84 atc250r's and 1 83
    - 2002 trx400ex
    - 1985 atc 250r
    -1985 atc70 WTB PARTS
    - 1985 tecate
    Sep 2006
    Northwest Indiana
    1,893
    How many miles on the 300? Oil pumps dont generally wear out. Clearance between bearing shells and journals causes pressure drop. Make sure you don't have a faulty sending unit.
    Jan 2005
    Jones, Michigan
    1,821
    Quote Originally Posted by tecat-z View Post
    right around 205,000. i just realized i had a book for this truck and it talks about an oil pressure switch, i think i'll try and test that out and see if its good. i'd think if it doesnt tick/knock then i'd be ok to drive it
    - Chick McGee
    -1985 250sx
    - 1981 110 chopper.
    - 1985/6 350x
    - 2002 trx400ex
    - 1985 atc 250r
    - 1985 tecate
    Apr 2006
    Crestview, Florida
    2,429
    sounds like main bearings or the oil pump pick-up is gummed up
    Rides
    85 ATC350X
    85 ATC200X
    Sep 2005
    central Illinois
    651
    best thing to do is install an aftermarket gauge (even if it's a cheap one and only temporary) and see what it reads. The factory gauges seem to only be good for reference and aren't always terribly accurate
