Finally got my hands on the XR200 and noticed the head pipe is huge, like 1 1/2 OD vs the 200x's 1 1/8 OD huge. It appears to have the same bends as the 200x pipe until about 3 inches behind the engine. Right in that area it will need one bend to kick the pipe out to the side around the back side of the frame but other then that it appears like it will fit like a glove. I'm curious if this is the stock head pipe for the XR or not. It also had a 29 mm mikuni on it rather then the stock 26 mm kehein so maybe someone upgraded the exhaust as well. Its so hard to find info on the XR for some reason. Its a 1980 model BTW.
