Results 1 to 11 of 11
Thread: '85 350x running like crap
    Aug 2006
    Texas
    997
    So, I take it for a ride after 1 month of sitting and find its spitting and sputtering at any throttle. I didnt screw with anything, but it ran great prior to storage. I clean the carb and install some new jets(stock). It still ran like crap. I have the mixture screw out 2 full turns, and plug is NGK at .25. Its a brown color but looks lean for some reason. Ill pick up a new plug tomarrow and try that, but if it still runs like crap, I dont know what else to try short of adjusting the valves. Any ideas what to try other than the plug? TIA~
    84 Honda 200ES Big Red
    WLL's Avatar
    WLL is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    pa
    317
    i hope its not that gay ass addative they are putting in the fuel
    [B][I][U][SIZE="5"] TURN THE SWITCH ON DUMMY!!! thada boy.
    click here and drag edog is gay over here [B][I][U][SIZE="6"]
    Oct 2007
    Anna, Tx
    165
    you could try some fresh fuel and see what happens..
    Apr 2006
    Crestview, Florida
    2,429
    I'd say the spark plug but could it be a clogged petcock or cap vent?
    Rides
    85 ATC350X
    85 ATC200X
    If it just sat then nothing really changed besides the fuel. If it sat, I'd take out the petcock, throw in a fuel filter and make certain that the carb is spot on. A mouse didn't make a nest in the A/B did he??
    Russell 350X's Avatar
    Mar 2003
    Steamburg/Randolph NY
    3,092
    Sounds like old gas, or a clogged petcock.
    TF 07,08,09,10,11,12,13,14!
    Aug 2006
    Texas
    997
    Can gas go bad after sitting just a month? Time to run the tank dry before storage then... Maybe these motors are that picky. Anywho, Ill do everything suggested and see how she runs afterwords. Nah, it airbox looks fine DC. Ive even tried running with w/o the air filter(UNI) and it still ran choppy. It seemed to be a little worse actually. Thanks!
    Apr 2006
    Crestview, Florida
    2,429
    Its not the gas after a month
    Rides
    85 ATC350X
    85 ATC200X
    scrawny's Avatar
    scrawny is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    WI
    181
    sounds like a plug to me
    thanks for the sig
    sponsorhouse.com profile: http://sponsorhouse.loopd.com/Member...er65/Home.aspx
    Aug 2006
    Texas
    997
    Ok, I got a new NGK and tried it. No change. After some riding and stalling and kicking 'till my leg hurt, the plug still looks lean. I cant get a pic since my camera wont focus, but I think it looks lean. Petcock is fine and flowing fuel fine. I checked to see that the float wasnt sicking starving it of fuel. It is operating just fine. I idled the motor and sprayed the intake area with WD40. There wasnt any revving indicating an air leak. I dont know what else to try here. Any other ideas? TIA~
    **edit**
    The cap vent was fine. Should I try going up or down on the needle? If so, should I raise it or lower it? (I dont know which is which)
    Jul 2006
    valves need adjusting
