Results 1 to 10 of 10
Thread: klt bogging. cant figure it out.
    evand is offline Just Too Addicted Arm chair racerJust too addicted
    Nov 2007
    MA
    523
    well the free klt is giving me some probs. it will rev fine in nuetral, revs fine in 1st, but shift second and i can only go about half throttle then it starts to bog and pop, like its runing out of fuel, but the pump is working fine. the more i turn the A/F screw out it gets a little better, but not much. i sprayed around the carb boot and base/head gaskets and no leaks. carb has been cleaned like 5 times. i cant figure it out
    thanks
    Evan
    Oct 2007
    Anna, Tx
    165
    whats the plug look like? that can tell you alot.
    Sep 2005
    Lipetsk, Russia
    2,824
    What's the air filter look like? Might be running lean. Oh and your gas might have water in it.
    Nov 2007
    MA
    523
    plug looks to be a bit on the black side, but nothing that would make it run like this. filter is new. gas is fresh
    Oct 2007
    Anna, Tx
    165
    Have you checked the timing?
    Apr 2006
    Crestview, Florida
    2,429
    First check the petcock and make sure the gas cap in venting. Then do a compression test
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2007
    MA
    523
    has a tank under the seat, and a fuel pump. no pet cock fuel flows great from tank to pump and the pump pumps like crazy. great compresion.
    Apr 2006
    Crestview, Florida
    2,429
    I didn't notice in your first post you daid it was poping, check your flywheel key it may be starting the sheer
    Rides
    85 ATC350X
    85 ATC200X
    Aug 2004
    Ab Canada
    4,368
    That have a Centrifugal step though clutch like a honda...?
    1985 Tri-Z-
    darrel632 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    alberta
    429
    check the wiring from the stator and CDI, had the same problem, when the CDI got hot it would do that. turned the plug black cause it wasn't firing right when at an idle. the other thing to try is try second gear with about 1/4 choke and see if it resolves your issue. a worn carb will do what your talking about by sucking air in the top of the slider if your O ring is shot or the seal is gone where the cable goes into the cap.
