Results 1 to 3 of 3
Thread: electric winch on a 200s?
    Jul 2006
    iowa
    451
    I am wanting to put an electric winch on my 200s. Is it possible to modify my wiring to charge a battery that will run the winch? I do have a voltage regulator from another atv. Can I wire the regulator to the 200s lighting coil, and then use the regulator to charge the battery? Before I buy a nice winch, I want to make sure I will be able to get power to it.
    McDerry is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2006
    Maine
    440
    you'll need to put in a rectifier diode to convert the ac voltage to dc voltage. in addition you'll need a battery and a battery box.
    Jul 2006
    iowa
    451
    I'm not worried about the battery or battery box, but where would I get a rectifier diode? could I use one from another atv? I have an entire harness from a 225dx (they have electric start) if any parts from it would be helpful.
