anyone seen some project like that. if yes send me link, info everything you know, i,m really interesting?
will a 2 stroke engine handle a turbo??
ALP
Beav
ALP
Beav
When there's a place to Jump, there's always a place to land. Don't matter if it's hard or not. Gotta find the limits of your trike.
1984 250r
Mods : Uni filter, 36mm Flatside Carb, Boyseen Reeds, P&P with a little bit of port timing (more to come), High Comp. Head, DG Full Exhaust.
1986 250R
Just got it give me some time to mod it
A 2 stroke will indeed handle some forced induction. I see guys running NOS all the time. Nos of course isn't quite the same, but its a similar principal. Detroit Diesel makes some 2500 (and up) horsepower 2 cycle diesel engines which are turbocharged.
The problem is mostly money. You can wring more power out of a 250r then the stock bottom end can handle without any means of forced induction with the right engine builder and component selection. Beef up the bottom end, and there is still room for improvement without the forced induction. If your goal was over 100 horsepower, and you had lots of funds, the turbocharger would be a viable solution. However, your going to run into problems with Fuel management and durability running much boost pressure. If you could hook up with a good engine builder, you might be able to get the fuel management and boost pressures down pat, only once you get the engine able to reliably handle the forced induction.
In short, its not a really viable solution economically. If you have the funds to burn, by all means...but you can get as much power in a 250r as you need for anything but hardcore sand drags without forced induction.
A few other points i thought up...
Routing! have fun getting a turbo into a 250r chassis, they are tight enough as it is with the 250 engine. you could possibly rig up a side mount, but there would still be a veritable jungle gym of tubing and the like. You could side-mount the turbo..but it would have a chance of being ripped off in many situations, making it even less versatile. Drag racing would probably be about all you could do.
powerband...2 strokes usually have a fairly narrow powerband, but this has been improved through the use of reedvalve induction and powervalves. A turbocharger will siginificantly up the rev range, and without some porting and other mods the 250r just doesnt make topend. You need a good deal of pressure to spin a turbo of a size that would make a significant difference. Add this to the fact that you typically want to run lower compression, and you will lose a TON of bottom end. Like I said before, turbocharging a trike would only be really viable for racing since it would make most of its power in the upper rev ranges.
Hope this helps, ill probanbly come up with some more ideas for you here as I sit and think it over.
It is VERY difficlut to Turbo or Supercharge a 2 stroke, It'll generally just blow the crankcase oil seals plus you've got poor'ish piston sealing too, get a 4 stroke to turbo, much easier.
The Detroit 2 stroke diesel had a sump with oil in the same as a car engine it just had inlet ports operated by the piston, the blower was just just push the exhaust gas out mainly, usually 4 valve per cylinder, all exhaust valves!
Nat
1979 Suzuki TS100
1984 ATC70, Broke
1984 ATC110, Repainted and Rebored.
1990 Suzuki SJ410
Unsuspended Antics.
umm that's what i call real information dude, thx alot Jonnhy Blaze
where to place the turbo? umm I think about it a bit and the solution i found is : put it where the sotck air box is and then find a new place for the filter. loll but i know it would be hard that's where i found a real prob
but i think before turbocharging my trike i'll bring him to a little 50-60hp :¬} (if i can) and keep it N/A
ALP
Beav
1984 250r
1986 250R
Yeah, no problem..You should have no problem at all getting 50 horses out of a 250, but it will cost some money.
I remember an article in dirt wheels about a turbo banshee. They had to find the smallest turbo they could find and felt that the banshee passed enough gases to turn it good. So I'd say it'd be way too difficult to do a 250 motor.
85 200x - Torn apart
ok, but if someday i try it i'll tell you all, and i think i'll take a turbo from a 3 cyl. firefly or the 9b from a 1.6l dodge colt sohc.
thx for all the reply guys
ALP
Beav
1984 250r
1986 250R
i'm back with the turbo idea but now it's only for general information for futher project maybe.
i read a lot of stuff on turbo and etc.
i found that a draw through setup would be more easy to do and less dangerous for the engine.
the room for a turbo isn't really a prob the real big problem is there : fuel and oil supply.
fuel supply : will the stock carb with larger main and idle jet would be enough?? or will it need an accelerator pump or a bigger carb??
oil supply : a turbo need oil to turn the problem is that a 2 stroke engine doesn't have an oil ¨reserve¨ for engine oil, it's already mixed with gasoline. so here's my guess on that problem; a box full of oil where the inlet and outlet of the turbo line would plug. would it work for the oil idea?
ALP
Beav
1984 250r
1986 250R
Another issue with this concept is the fact that you are only dealing with 1 cylinder. Has anyone ever seen a single cylinder turbo? I doubt it. If one does exist, it more than likely is a crappy prototype that did not work. The other problem that was stated earlier is that it is a two stroke. There just isnt enough top end exhaust pressure to run it. A banshee would be better due to it being a twin, that way there is a more consistent flow to the turbo. There are many problems associated with turbo charging a single. If you really want boost, I would first try super charging. I forgot that another reason you cant turbo a two stroke is because of the reeds, you need to convert to an electronically controlled fuel injection.
83 YT 175
85 ALT 125
Turbo sleds are common, but of course they are fuel injected, powervalved and usually 2-3 cylinders. The real mystery is how they oil them, because you cannot use 2 cycle oil, it has to be 10W-30 or thicker to even be safe. You have to have a constant flow of oil and coolant also to the turbo to keep it alive for any longer than 5 sec. There are turbos without coolant lines, but the oiling is still a problem. Little electric motors? That's all I can think of, those turbos spin at around 30,000 RPM too. I'm sure a snowmobile board would have a awnser to all our questions. It wouldn't be that hard to turbo a 250R I dont think, just a lot of custom intake an exhaust work, with the carb before the turbo. I'm sure a super small turbo like someone mentioned erlier would have no problem spooling up with the 250r, you would need a forged piston and rod at least to hold up to the boost though. You would have to clean out the exhaust often also because of all the oil in it. I'm sure you would have to run a fuel pump too. All in all it would be more worth your time to just get the power out of the motor N/A because it's easier and more reliable. A turbo 250R of any sort especially a 3 wheeler would be sweet though.
1986 ATC 250R(for sale), 1963 AceCraft boat w/40HP Evinrude, 1981 Arctic Cat El Tigre' 440 L/C, 1992 GMC Safari Van.
check this $h!t out!
Wanna race? ;-)
85' Tecate (still looking for entire front brake asembly...)
bonanza mini-bike
if you cant ride with the big boys...put it back on the trailer
ONE THING AND THE MOST INPORTANT IS ,,, the two stoke 250r uses a expantion chanber to scavenge fuel and exahust gas putting a turbo on eliminates the effect of the pipe... it wont ever work properly,,,, cause you will never get a sound wave back thru a turbo to help close off the exahust port ,,,,,,,,,,, which is very important in a two stroke engine,,,,,,,,,,,
turbo goes after the expansion chamber.
Sam from Florida
1985 BIGRED $ 200X
its not a two stroke but it is a blown twin carb 50 engine
Hoarder of the finest junk
'82 YT175
'83 YTM200
'85 KLT110
'86 Moto 4 225
'84 TRX200 trike conversion.
'87 Tecate 4
