Thread: Z rotor question
    Jan 2005
    RI
    2,530
    Z rotor question
    Hey...
    bent the hell out of my z's rear rotor. Ive read about swaps for it and such but id rather not mess with it.
    Does the z front rotor fit the rear?
    Thanks,
    Mike
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Jun 2006
    Ohio
    2,294
    Yes.But you have to add 3/8 inch spacers to the rear caliper bracket to shim it over and add longer caliper bracket bolts.Other than that,they are the same diameter and bolt pattern rotor.
    Here is a link with more info.
    http://www.3wheelerworldforums.com/s...ad.php?t=75546
    1981 ATC 70
    1978 ATC 90
    1985 ATC 250R
    www.cosmicquads.com
    Feb 2006
    AZ
    1,358
    I have a rear disc for you. Prob in better shape than yours right now. I will check how flat it is. I cant remember but i think i replaced it due to hub was loose (still attached). I also think banshee and maybe blaster is your options. I dont think the front is the same but i need to check on mine to remember.
    Let our local tri-z guru Raffa check in for retrofitting other discs. He's ripping up the trails....
    '86 Tecate
    '85 ATC 250R
    '85 Tri-Z
    '87 ATC 200x
    '85 ATC 250R - Rider
    '86 Tecate - Rider
    Terryville,CT
    1,616
    i think mosh already answered it! why not just get an oem from www.cheapcycleparts.com or www.bikebandit.com not that
    expensive! ok so its 87$ alittle more then i thought and i would take a couple weeks to get to ya!
    2- 85 250SX's
    1- 85 200X
    3-ATC 70's
    Was someone riding in N H without a skid plate?? lol.......
