hey i have a 84 tecate stock bore wisico pistion,stock reeds,dg pipe,stock carb needle is in the 4th slot down from the top (stock ) jetting is also stock no air box direct filter.where should i be for jetting atleast a good place to start,i run motule oil 50:1 mix same as my banshee thanks for the help i think were around a 1,000 feet above sea level + or - acouple
