will a ascott 500 head fit onto a 350x im putting a 425 bigbore kit and i want bigger valves what will it take to make it fit
from the looks of it its quite a bit of machining and work, but i really bet it pays off in the end. http://www.3wheelerworldforums.com/s...ad.php?t=78141
the ascott head is built to work with a 89mm bore...add a 6mm stroker to this and you got a 460cc motor that will out run most
with the 89mm bore (xr500 piston and sleeve) you get to run off the shelf parts and gaskets, not hard to find custom stuff
just read my thread hondahaulic posted and see what it takes
WWW.HREATV.COM
