Thread: 85-86 250R Front brake master
    Apr 2008
    FL
    144
    Howdy all,
    So my front brake works fine (for now) on my '86 250R. The master cylinder however is showing signs of wearing out and just over all nasty looking. The brake line also isn't all that great either.
    So, I noticed that some times master cylinders (with lever) and lines fit from other bikes.... The OEM stuff costs a truck load, I think I saw it listed at $250.00 just for the master cylinder alone.
    Anyone ever replace the front master and line with something else and have it work well and not be ghetto?
    -BFC
    '86 250R
    Sep 2003
    Elizabethtown PA
    1,581
    get the stuff from a newer cr85 or cr150 4 stroke one ebay. they come with braided steel lines from the factory.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    Tionesta, PA
    5,747
    I find that Banshee front MCs are a dime a dozen - works well too because they are designed to push dual calipers up front.
    MyMistress86R's Avatar
    MyMistress86R is offline HEY! I don't really like your attitude right now! Arm chair racerJust too addicted
    Jun 2004
    Ohio
    1,026
    Yammie Raptor 660 units are also a good option. Got mine off eGay for $8.50.
    Official Wellsville soil tester! With pics and a $3000 medical bill to prove it...
    1986 TRX250R
    ESR 310~trail ported w/ torque exhaust flange~36mm Keihin carb~v-Force3 reeds~Pro Circuit Exhaust~custom 16oz flywheel weight~2006 YFZ front shocks~adjustable rear dogbone~fully functional rear brake light~Durablue +4 axle
    Former Ride 1986 ATC250R
    Back in Happy Valley
    833
    I agree that the yamaha levers a cheap, but i kept the stock one on my 350x and added a set of new braided lines for the front and rear. New lines are a little costly (10mm ends are sold separately) but they look good and i dont foresee any major issues. So although my stock date coded hoses weren't damaged/leaking it was just an upgrade i felt was worth it...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    Apr 2008
    FL
    144
    Thanks for the suggestions fellas!
    -BFC
    '86 250R
