2 of the 3 scramblers at TF07 had the same problem, its happened to my P3 a few different times as well. You either have the floats set wrong of your needle and seat is warn / clogged. You have gas in your base, filled up around the crank / rod, fluid-locked. If you look at the under side of your motor you can see a small drain plug, its pretty obvious what it is once you look for it. pull it and drain your base. I showed it to jswinehart at TF07, drained his and he was back up and running.
Howdy or jswinhart might have a blowup picture to show you better.
GOOD LUCK
MIK6 / Mike
New England Ride 4/13
