Originally Posted by
wolfspider
hi can i use an 86 axle in a 85 350x? and will a 85 bearing carrier fit in an 86 swingarm?
any help appreciated.
cheers steve.
Yes - axles the same
Yes - 85 to 86 carrier swap
No - 86 to 85 carrier swap UNLESS you change the rear sprocket/sprocket bolts to the tapered 86 setup as well. If you change the rear sproclet and bolts, then a 86 to a 85 will work.
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
