Results 1 to 13 of 13
Thread: Can someone post some pictures of an 86' 350X bearing carrier and swing arm
    VenomRS4 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    Massachusetts
    418
    The rear brake and axle set up on my 350X is definitely not put together correctly and missing parts. Also, I think my swing arm has been modified. So, can someone post some pictures of their 86' 350x rear end set up. The more detailed the pictures are, the better.
    Thanks!
    My current stable:
    1981 Honda ATC110 (sold)
    1986 KTM 80 MX (for sale)
    85+86' KTM 500MXs (sold)
    1973 Yamaha AT3 125
    1971 Suzuki MT50 Trailhopper
    2005 Kawasaki Ninja 250 (for sale)
    2000 Ducati SuperSport 900ie (for sale)
    WLL's Avatar
    WLL is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2007
    pa
    317
    can ya post up some pics of your setup?
    [B][I][U][SIZE="5"] TURN THE SWITCH ON DUMMY!!! thada boy.
    click here and drag edog is gay over here [B][I][U][SIZE="6"]
    Back in Happy Valley
    833
    Mine, not sure it if will help, 86 swinger +3, 86 brakes, aftermarket carrier, and 85 hubs/sprocket and rotor...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    Feb 2007
    Massachusetts
    418
    I cant post pics of mine....ive already taken it appart. Ive also come to the conclusion that I need a new swing arm though....damn!
    My current stable:
    1973 Yamaha AT3 125
    833
    I know a guy in Fl that has one of those laying around. BTW what did you pics of specifically? i maybe able to help you out this evening...
    Feb 2007
    Massachusetts
    418
    If possible
    -The rear brake set up...like how everything is bolted up and where
    -the bolts and stuff on the axle itself. Like the sprocket and brake hubs and how they go on.
    -a view of the swing arm from all sides
    Any pics would be very helpful. And if someone could tell me the order in which you put the bolts, sprocket hub, etc on the axle...that would be great too.
    Thanks
    My current stable:
    1973 Yamaha AT3 125
    travis712's Avatar
    travis712 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Maine
    157
    Have you attempted getting the swinger bolt out yet? Good luck with that..
    Here's a link that might help you figure out what you're missing.
    http://www.bikebandit.com/houseofmot...x-1986/o/m1917 and go to the rear axle diagram.
    86 200x- finally all back together
    travis712's Avatar
    Maine
    157
    You might get lucky, but chances are you won't, haha. When the bolts being stubborn, the best advice I've heard to get them out is heat(torch) and an impact wrench. The bearings inside usually bind up and it's damn near impossible sometimes to get them out. A lot of people end up cutting the swinger bolt to remove the swinger. On my 86 200x, I could not get the swinger bolt out. We actually started bending the frame we were putting so much pressure on it. Heat is the key I think.
    833
    Ok here's a couple pics (you'll have to excuse the mess its in a ton of pieces, but as far as assembly goes:
    1 put the carrier in the swingarm and install the snap ring/brake bracket (86 bracket pictured) When the brake bracket is installed on the 86 you need the spacer/snap ring, or on an 85 the arm needs to be bolted to the swinger extension
    2 slide in the axle from the left with the sprocket hub in place, or the right with the brake hub installed
    3 install the opposite hub and ring on the axle
    4 install the fade nut hub/assy and the ring on the right side of the axle
    5 tighten the fade nut to the point you have no side to side play inside the carrier
    6 tighen the chain and then finally the two allen bolts on the rear of the swinger to keep the carrier from moving.
    Attached Thumbnails Attached Thumbnails IMG_3572.JPG   IMG_3573.JPG   IMG_3574.JPG   IMG_3575.JPG   IMG_3576.JPG   IMG_3577.JPG
    Feb 2007
    Massachusetts
    418
    Quote Originally Posted by travis712 View Post
    What if i cover it in penetrating oil overnight and use an impact gun? And can i still get bolts for it?
    My current stable:
    1973 Yamaha AT3 125
    Feb 2007
    Massachusetts
    418
    Woah....holy screwed up post pattern......................... How is it Im the last "commenter" (is that a word...if not, it should be) but it gets posted before a comment I made an hour ago?
    wierd
    My current stable:
    1973 Yamaha AT3 125
    Feb 2007
    Massachusetts
    418
    travis712, I have not tried yet. How hard isit to get out? Any tips to speed the process up?
    i58829, thanks for the info and pics, it helps a lot. And oh man, im missing a lot of parts.......
    My current stable:
    1973 Yamaha AT3 125
    saladboy's Avatar
    saladboy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2006
    michigan
    181
    heres the pics,the only thing thats missing is the collor that covers the snap ring.oh yeah no swinger bolt.
    Attached Thumbnails Attached Thumbnails 200s parts 055.jpg   200s parts 053.jpg
