Can I use an '86 250R master cylinder on an '86 350X? I mean are they the same?
I have both bikes and they sure look similar. My 350X master cylinder looks funky. The little window is all fogged over. And the little rubber boot on the brake line is in a chemical melt down from what I would suspect is from brake fluid. But the brakes work great and I don't see any leakage. I wanted to keep it all original but perhaps this is the one item I should modernize with a braided line. Are you out there 3razors? What do you think??
