Thread: 86 250r crank vs 87-89 trx..
    Mar 2008
    kearney, nebraska
    51
    what is the difference between these two cranks.. i need a new and bought a trx one tonite..without checking application..
    1986 350x
    1986 200x
    1986 250r
    1986 250sx
    1985 TRI-Z
    1984 70X
    2006 yamaha 110(clone)
    2007 yamaha 110(mini clone)
    2004 kazuma 110 atv
    1994 z-50
    1998 YZ80
    Sep 2006
    Northwest Indiana
    1,893
    87 up engines used a longer rod. You can use your new crank with a 87 up style piston.
    Mar 2008
    kearney, nebraska
    51
    Is That The Only Thing I Will Need To Do..any Adapter Plates Or Anything??
    1986 350x
    1986 200x
    1986 250r
    1986 250sx
    1985 TRI-Z
    1984 70X
    2004 kazuma 110 atv
    1994 z-50
    1998 YZ80
    USA PENNSYLVANIA
    102
    if you use an 86 piston you need a spacer plate.87 and up piston no spacer plate.
    Jun 2003
    englishtown NJ
    2,676
    also you will need longer studs, 2 base gaskets, and longer collarss. Esr sells the whole thing you need for like $50
    Mar 2008
    kearney, nebraska
    51
    so if spacer plate is used longer studs and so fourth..but 87 piston is bolt on ? and go..
    1986 350x
    1986 200x
    1986 250r
    1986 250sx
    1985 TRI-Z
    1984 70X
    2004 kazuma 110 atv
    1994 z-50
    1998 YZ80
