Results 1 to 7 of 7
Thread: My Piston with 150psi
    Nov 2002
    Chezzetcook Nova Scotia
    1,836
    Here is a picture of my was new piston. It had 205 ish psi when rebuilt.
    I blew up my other top end the same way.
    Except I changed my
    stock reeds for V force 2 reed cage with grey backer"I was told these are junk?
    Thought it was my crank so I sent it away and had a hot rod kit instaled.
    I had my other cylinder resleeved and bored out to the max.
    It is hard to believe that this pisture had This for compression.
    The compresion tester reads in 50s.
    So the bike ran great. No complaints until it just "blew"up. I was racing a 1980 km 100 kawasaki dirt bike or at least a bike anyway.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Apr 2006
    Crestview, Florida
    2,429
    You need to run alitlle more clearance and the gap on those c-clips should be down
    Rides
    85 ATC350X
    85 ATC200X
    Aug 2004
    Ab Canada
    4,368
    Quote Originally Posted by Erics350x View Post
    Yea, 19 thou on the end gap, 70 on the pin 03 on the piston/cyl and let it break in nice
    1985 Tri-Z-
    Nov 2002
    1,836
    Huh?
    It worked great. I did what I was told to the cylinder. But what could have cause it?
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Apr 2006
    Crestview, Florida
    2,429
    Quote Originally Posted by Tecate250 View Post
    Huh?
    Look at that picture again, it didn't work so great. Another thing to look at is port chamfer. You should also go through the carb on a 2-stroke anytime you do a top-end. Running lean is the #1 killer of 2-stroke's
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2002
    1,836
    I have not touched the carb at all. I did chamber both cylinders and they came up almost the same. Except the marks are on the front and back unstead of the sides. No Damage to the cylinder just some aluminum was welded to the piston.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Nov 2002
    1,836
    Ever get tired of waiting for parts? I ordered my piston 2 months ago.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
