Results 1 to 2 of 2
Thread: 1979 yamaha xs 400 help
    adam is offline New to the board Arm chair racerNew to the board
    canada
    39
    we have an old yamaha xs 400 and when we start it up it idles good as soon as you touch the throttle it revs up and stays at a higher rev and sometimes as soon as it warms up it does it to. we have cleaned the carbs the carb boots had cracks in them so we used silicone type sealer to seal it.
    Thanks any suggestions would be greatly appreciated
    Adam
    Six Stroke's Avatar
    Six Stroke is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Central Minnesota
    315
    Ww had an old Honda CL450 that did this too. The problem as far as I could tell was the slide blowing open at low RPMs. They're a diaphragm type slide, so they're pressure controlled instead of being connected directly to the throttle cable. It's hard to pinpoint why it does this, but I'd check to see if you have even compression and check for air leaks. Also, check to see that the diaphragms are in there properly and that the slide is moving freely.
    Another thing to check is to make sure that the cable isn't hanging up at the splitter junction (considering it has one.)
    1985 Yamaha YTM225DX
    2014 Yamaha WR450F
    2008 Yamaha TW200
    1975 Honda CB400F
