Thread: 200x Value and some pics.
    Aug 2006
    CNY (Oneida County)
    65
    Value and Opinions, What do you think its worth?
    http://dreamscape.com/dstewart/
    What was done
    Powder Coated Frame and Swing arm – White
    Gas Tank reconditioned and repainted
    New Handle bars
    Meier rear fender and stock front
    Engine rebuilt:
    12.1 High Compression Piston from Wiseco .20 overbore
    Head Rebuild and valves cleaned and reseated
    New Clutch, Fibers, springs (VESRAH Heavy) and Plates.
    Carburetor altered and opened up and matched to the manifold (No Choke, has been removed) rebuilt with new needle and seat new UNI Filter.
    New Cobra Exhaust – Header and muffler
    New Clutch and Front Break Lever
    New Chains and Sprockets 12/40 Stock gearing
    New Swing arm bearings
    New Axles Bearings
    New front Axle bearing
    New Brake Pads front and rear
    Just mainly curious
    Thanks
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    $1,000..............
    Apr 2006
    Crestview, Florida
    2,429
    Quote Originally Posted by edog View Post
    ^^max^^^^^
    Rides
    85 ATC350X
    85 ATC200X
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    /\/\/\For shur/\/\/\
    Nov 2002
    Kirkville, NY
    3,831
    I would say from $800 - $900, you might hit $1000 if you find the right person and get lucky. I assume it runs perfect and everything works 100%.....
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Aug 2006
    CNY (Oneida County)
    65
    yea 2 kicks usually to start it and go ....
