I just noticed that my sprocket hub has some play on my lonestar axle. I've also read where thats quite common. How big of a deal is that?- should it be replaced right away or just run it?
that usually happens when the axle lock nut/anti-fade is loose. Check the axle nut, tighten it. And if it keep loosening, your anti-fade is worn and/or your carrier bearings. No, that isn't common to happen. With proper maintence, it should stay tight w/o play.
i'd say its fairly common with aluminum sprocket hubs.
iv seen plenty wear out
WWW.HREATV.COM
I had a few wear out also, the culprit was the anti-fade was loosening. A few bad carriers also. No more play in the hubs since.
no matter how tight the axle nut is with a torquey 4 stroke they will ware out sooner or later..... hell, iv seen a 350x tear the sprocket bolts right out of an aluminum hub
i know he has a r but it does happen
WWW.HREATV.COM
