Are there any common problems with 2nd gen tecate 3s? Im thinking about picking one up....but I am not sure what to look for. Any help would be greatly appreciated.
Thanks
Thanks
My current stable:
1981 Honda ATC110 (sold)
1986 KTM 80 MX (for sale)
85+86' KTM 500MXs (sold)
1973 Yamaha AT3 125
1971 Suzuki MT50 Trailhopper
2005 Kawasaki Ninja 250 (for sale)
2000 Ducati SuperSport 900ie (for sale)
well all i can really think of is the stock stator and flywheels. typical on t3's for the magnets on the flywheel to come loose. check the shock to, more then liekly if its been ridden hard , it will need a rebuild as well.
yep what he said ,just got done doing a stator on mine and the shock was wasted when i got it![]()
2003 banshee ported jugs,piped,yad-ah,yad-ah
1986 tecate KX5 swap
1986 350X(cammed ported piped)sold
1985 250R(310 klemm pipe)
1985 atc70 x 2
other toys
1995 mustang cobra 6 speed twin turbo
1075 rwhp 963 rwtq
9.25@156mph
1992 GMC typhoon 402c.i. LS1
4L80E AWD twin turbo a/c power steering and cruise
963 AWHP
9.40 @ 147 on 4 drag radials
Also the rear swing arm bolts strip out
i also had a bolt stuck in my tank as well. i ended up drilling it out and helicoiling the hold. i had to grab the brass insert with a needle nose while i drilled and tapped the insert. hornet powersports sells new sets of radiator shrouds and headlight covers, and chaplin kawasaki sells repro. decals and the rest of the plastics except the gas tank which you can't buy anymore. i used redkote on my tank and am having it color matched and painted. also alot are missing the coolant overflow tank as well. i still don't know why they are missing them, but you can't buy those anymore. front and rear rotor bolt like to freeze in the holders and the allen head strips out. i had to drill 3 of mine out and helicoil one. kawasaki doesn't sell the bolts anymore, but rockhound motorsports has stainless and standard bolts for sale. also kawasaki doesn't make a piston for it anymore so you have to go with wiseco. overall i think they are the best looking trikes. can't wait to get mine done.
1986 Kawasaki KXT 250 tecate
ported, FMF pipe, DG silencer, boysen stage II reeds, 39mm keihin PWK, T4 thumb throttle and front master
All the above and the Nikasil coating gets worn off the cylinder, there are very few exhaust choices, the short straight carb mount is discontinued.
http://providence.craigslist.org/mcy/708363946.html
your like me looking atthe same stuff
NO 3 WHEELERS CURRENTLY SOLD THEM ALL![]()
02 GSXR 240 kit STRECHED
03 BANSHEE 421 CUB
07 LTR 450
08 RZR
05 f7
07 KLX 110
670 ho skidoo powered banshee
1985 nacs kx 80 race quad
I would buy that in a heartbeat!!!
Its definitely worth $1000 as it sits. What a lot of people don't know about them is that the powervalve actuator assembly has a reverse thread bolt on it. they get broke all the time. there is only a few ways to mess the valves up, both easy fixes. throw in the spare parts you have 3/4 of a 2nd T3. I've seen rollers go for $5-600 easy.
MIK6 / Mike
New England Ride 4/13
Bolt comin loose from vibration seems to be a common problem on all older Kawis... Keep your tools close
