85R hubs fit on 84R axle???
Do the 85r hubs fit on the 84r axle?
Airfoolers RULE!!!
No, they do not. If I may ask, why do you want 85 hubs on your 84? If you need the bigger diameter wheel studs from the 85 hubs on your 84, you can use the 85's studs in your 84's hubs.
no 84 has 24 splinned axles, 250ex/400ex/450r hubs fit, that would give you a bit more width, also blaster, tri-z banshee, warrior hubs fit if you want a yamaha pattern. the 85 up atc/trx has 25 splinned axles same with the 350x.
//ArrowChat Integreation Code
