Thread: Where can I find Tri-Z performance parts?
    VenomRS4 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2007
    Massachusetts
    418
    I know about sprock racing but other than that, I cant find much for Tri-Zs. Whats available and where do I look? Are there any big bore kits still available?
    My current stable:
    1981 Honda ATC110 (sold)
    1986 KTM 80 MX (for sale)
    85+86' KTM 500MXs (sold)
    1973 Yamaha AT3 125
    1971 Suzuki MT50 Trailhopper
    2005 Kawasaki Ninja 250 (for sale)
    2000 Ducati SuperSport 900ie (for sale)
    N.E. Ohio
    2,005
    DG makes pipes and silencers, alot of folks have gone to larger PWK carbs with open air filters. Moshman, Cosmic Quad has a line on, fork caps, Vforce reed cage/reeds. You would need to contact Corey Sprock about the big bore...not real sure if there are any left. E-bay isn't full of stuff but unique pipes show up from time to time. There is a Guy on this site who makes some stainless axle and swing arm bolts. Anouther guy offers a complete stainless bolt kit...keep searching this site you'll find it.
    springville, PA
    6,185
    Here is a post I made about a week ago
    Quote Originally Posted by Me
    Any thing on the rear end will interchange with banshee except the disk brake hub i believe
    Shock will interchange with warrior
    Progressive Suspension makes a great front fork spring upgrade
    DG has aftermarket pipes, also apparently jemco will make a new one if you order it
    Keihin for your carb needs
    Boyseen and VForce for reeds
    Sprock Racing (tritecate350 here on the boards) for clutch baskets, upgraded intakes, cool heads, and probably a few more things
    GreenBoy (hagen) here on the boards makes IMS style footpegs and polished stator covers
    Sblt500r (on the boards) has polished shifters, motor mounts, Boost bottles, and oil caps
    Ronnie (YamaHondaman) has stainless bolt kits, knerlded oil caps, stainless swingarm bolts, headlight grills, impellers, inline coolers, thermostat deletes and i'm sure I'm forgetting quite a bit
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Aug 2005
    Lockport, NY
    2,395
    No bigbores left unfourtunately...
    Sep 2005
    central Illinois
    651
    do a search for the tri-z parts interchange thread, quite a few parts interchange with other models which can open up more options for you
