Results 1 to 8 of 8
Thread: Need some serious help
    May 2008
    Centerville, IA United States
    So I just got my honda 250sx up and running and was out riding it the other day and rode it around for like 30 minutes and it was running like a dream. I was going along with it wide open then all of a sudden it started cuttin out real bad like wanting to die. and every time i tryed to go past 1/2 throttle all it wanted to do was cut out and try to die. I adjusted the pilot screw and had no change. I had cleaned the carb up real good before I took it out. Anyone have any ideas as to what the problem might be? Thanks Coreybob
    Feb 2008
    NE Indiana
    525
    I was riding mine really slow after unloading it the other day, and it just cut out real bad, and wouldn't start. I did some digging, and you know what I found? My 5 year old son & his little friends wanted to go riding on it while I wasn't around, so they put about 32oz. of water in the tank, thinking that would do it. I was a little upset, but they didn't know any better. About 2 hours of work, and $10 of wasted gas, and I was up and running again. It'd be a long shot, but check the quality of your fuel. I was very surprised to see a milky stream coming out of the fuel valve when I checked for flow. I would have never guessed in a million years I'd have water in my fuel. It's one of those random things. Thank goodness the key wasn't in it. He's not allowed to sit on it now unless I give him permission. He used to sit on it & pretend he was riding, but those days are over for now.
    Good luck.
    smvorndran
    WaimakRydah's Avatar
    WaimakRydah is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    New Zealand
    421
    ive got a similar problem with my 200S but it only happens above 3/4 throttle what happened was. I had a leak out my over flow and it was running great apart from that but i adjusted the float up too high which stopped the leak and made it bog at high RPM mine doesnt feel like it wants to die though it feels like its not getting enough fuel for the high revs I'll keep experimenting till i perfect it but i still ride mine like that i just shift gears sooner.
    1985 Honda ATC200S
    1994 Kawasaki Eliminator EL250
    Feb 2008
    NE Indiana
    525
    A spark plug is a cheap thing to replace. I'd try that. Very rarely do they go bad on 4 strokes, but they're so cheap, it's worth a shot. Also, check to make sure you didn't bump the kill switch.
    smvorndran
    UlsterATCFan's Avatar
    UlsterATCFan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Feb 2008
    UK
    363
    Quote Originally Posted by smvorndran View Post
    Good luck.
    smvorndran
    Sounds like a couple of trike enthusiasts in the making
    Nov 2002
    Chezzetcook Nova Scotia
    1,838
    Could be a cloged gas cap.
    1985 KXT 250 Tecate
    1983 KX 250
    Proud member of
    3wheelerworld.com
    3wheeler.org
    Planettrike.com
    Airfoolers.com
    Apr 2006
    Crestview, Florida
    2,429
    if theres trash in the fuel, your carb prolly clogged again. i'd drain the tank and fill with clean fuel, clean the petcock and carb, and check the fuel cap vent.
    Rides
    85 ATC350X
    85 ATC200X
    PA
    3,515
    iv had the main jet fall out...this kinda sounds like what you are going through
    WWW.HREATV.COM
