Results 1 to 15 of 16
Thread: Alright, what did I do wrong? ( 1986 200x)
    Twilight is offline Check my feedback before buying from me Roostin Away
    Nov 2006
    Seattle
    1,552
    I finally got around to replacing my broken kickstart and after I got it all together I have realized it kicks over way too easily and wont start for me. I can get the compression up to 150, but it takes about 10 kicks to do so. I havent put the oil back in yet and was wondering if that could be why? Or could I have installed something wrong?
    Oct 2007
    Anna, Tx
    165
    i'd put oil in it 1st and then check your valve clearance. you could have a valve hanging open.
    85 200x
    84 200x-autox
    84 200s--parted out
    85 70
    85 70
    84 70
    69 QA50
    70 trail70
    81 yz250
    82 yz80
    Nov 2006
    Seattle
    1,552
    Before I did this though, it started within 2 kicks, how can taking the case apart mess up a valve?
    Apr 2006
    Crestview, Florida
    2,429
    you have the decompression lever wrong
    Rides
    85 ATC350X
    85 ATC200X
    Nov 2006
    Seattle
    1,552
    any idea on how its wrong? sorry but i followed the manual completely and ive done this like 4 times...
    Oct 2007
    Anna, Tx
    165
    dunno, how it happens, but I just built a 85 200x motor, and it did the same as what happened to you, on mine the intake valve was too tight, it had less than .002 clearance when is should have been .003 to .005. it's something worth checking...
    85 200x
    84 200x-autox
    84 200s--parted out
    85 70
    85 70
    84 70
    69 QA50
    70 trail70
    81 yz250
    82 yz80
    Jul 2006
    iowa
    451
    I would put oil in it, that could make quite a difference.
    current rides:
    05' 400ex
    02' yz85
    84' 200es big red
    84' 200s with tlr200 engine project (almost done)
    84' atc 110
    83' 225dx with 340cc kohler sled engine
    Back in Happy Valley
    833
    I agree, put oil in it before anything else. I personally wouldn't crank it over without oil, even if its cheap stuff just to see if its gonna fire you need something in there...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    Apr 2006
    Crestview, Florida
    2,429
    oil isn't going to make a difference
    Rides
    85 ATC350X
    85 ATC200X
    Apr 2006
    Crestview, Florida
    2,429
    Quote Originally Posted by Twilight View Post
    Then maybe its the first time you got the decompression right. Watch the lever as you kick it over. It should start off released, activate at about 1/4 kick, and release right after.
    If you arent sure unhook the cable and see if it changes anything. Decompression is for wuss's anyway
    Rides
    85 ATC350X
    85 ATC200X
    Mar 2008
    Tug Hill
    1,282
    ^ i agree just eliminate the decompression cable its usless if you have a strong kick
    Nov 2006
    Seattle
    1,552
    haha I actually disconnected it just now and it started first kick! woohooo!!!
    Bad news is I must have did the clutch wrong, because its not engaging =\ How much should I torque the springs down? I know not to bottom them out, so they are half way right now.
    Jan 2005
    RI
    2,530
    the clutch springs both have a really low torque value, like 7-10 foot pounds.
    you didnt tighten them down all the way? How are they supposed to work if the bolts that go through the springs arent tight?
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
    Nov 2006
    Seattle
    1,552
    so... that means I do tighten them down all the way? I went by the manual just now and it says 2-3 turns in, but thats barely finger tight!
    Jan 2005
    RI
    2,530
    yeah, the springs need to be tight in order to hold the clutch plates tight against the steel plates...hopefully nothing rattled out and broke while you had them that loose
    1986 Tri-z
    1985 250r
    1985 200s
    1985 70[/SIZE]
