fluid locked. happens alot on T3s.
do you leave your gas on? if you do, the needle / seat will let a small amount of gas pass by. it drains down into your base, it won't start w/o a drag start. if you chose to try that route, watch for more smoke after the crank seals get damaged doing it. i use a winch and hang it streight up and down from the frame/ axle. pull plug and exhaust, kick it over slow, gas will work its way out.
MIK6 / Mike
New England Ride 4/13
