Thread: Trizinger yt60
    Jun 2003
    11
    Trizinger yt60
    I cannot find where to drain the cankcase oil on my tri zinger. Also, there is a hose running to a fitting on the drive box. It was disconnected when I got the trike, so I reconnected it. Is it for feeding oil, or some type of vaccum throttle compensation mechanism for the clutch.
    I had a nightmare that the hose was for an oil line and that since it was disconnected, it drained all of my crankcase oil. Anyway, the trike used to run intermittent, sometimes it would have a lot of power, others it had no power, kept running though. Any help is appreciated.
    Ashland City, TN
    2,576
    The hose to the drive box is just incase the drive box oil overflows, no big deal. Most likely your dran plug is on the very bottom towards the rear of the engine, it should be a hex-head bolt. Good luck.
    Trikes:
    1973 Honda ATC70-orange!
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Jun 2003
    11
    Awesome, I'll go look again for the drain plug. What type of oil goes in the rear drive shaft assy thing?
    Ashland City, TN
    2,576
    I think pretty much any 80 weight gear oil will work. Just be sure don't to overfill!
    Trikes:
    (2)1985 ATC70
    1985 Big Red 250
    1985 250R
    Jun 2003
    11
    Ah, thank you much for your help. I found the oild drain plug. It was mounted horizontally so I thought it was an engine mount bolt.
