Results 1 to 7 of 7
Thread: Tightening chain on 200S?
    WaimakRydah's Avatar
    WaimakRydah is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    New Zealand
    421
    How would i go about tightening the chain on my 200S
    1985 Honda ATC200S
    1994 Kawasaki Eliminator EL250
    Hampton, Virginia, C.S.A.
    2,664
    there is four bolts that hold the rear axel and hubs to the frame...loosen them and then tighten the little adjuster that is at the bottom left side its real easy
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Apr 2008
    New Zealand
    421
    Im not 100% sure of what u mean. Would u be able to get some pics and highlight what bolts il need to adjust
    1985 Honda ATC200S
    Apr 2006
    Crestview, Florida
    2,429
    you need to download a manual or earn enough $ to pay a mechanic
    Rides
    85 ATC350X
    85 ATC200X
    2,664
    get behind the 200s right by the muffler...look for where the rear axel assembly mounts to the frame...there are for i believe 17 mm bolts you will loosing...then tightind the adjuster to the bottom left hand side
    current rides
    82' ATC110
    85' ATC310R
    85' ATC250R
    85' ATC250ES
    16' brute force 750
    Apr 2008
    New Zealand
    421
    i still dont see what the point in loosening the axle bolts is there is 2 on each side right? Why should I loosen the ones on the opposite side to the chain?
    1985 Honda ATC200S
    NE Arkansas
    2,344
    Because the whole carrier moves when you turn the 12mm adjusting nut. Don't bite the hand that feeds ya, we try to help and get nothing but flack from ya. Your name isn't James is it?
    My Rags
