I am wondering if there is a way to take the carb off with out having to cut the oil injection lines? and if I can't where can I get new ones?
Thanks
Thanks
My carb is stuck, I mean frozen stuck can I remove the throttle cable off of the slide with out being able to move the slide?
Thanks
That would be very hard to do. First you have to make sure that you have all the slack at both adjusters, the adjuster at the top of the carb and the adjuster at the thumb throttle. When you have backed the 2 of those off so you have full slack, then you have to try and push the throttle cable down through the slide and slide the cable to the outside of the inner wall of the carb and then if you have enought slack the cable should come up through the slide.
I got the carb cleaned up and now the trike runs pretty good, just need to do some fine adjustments to it.
Good, it's always nice when your hard work pays off and things work out like you want them to. How about some pictues?
