Thread: Suzuki LT80 Clutch Help
    kdagenais is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2003
    254
    Hello,
    I am working on a Suzuki LT80 and have a clutch problem. It doesn't have any stall at all from a dead stop and causes the engine to be overloaded at first. Not sure which clutch is the culpirt and what to look for once it is identified. Any help will be appreciated.
    Dec 2002
    Kansas
    2,387
    Remove the front clutch, I'm sure you have rollers that have turned sideways causing the problem. If you want some awesome performance only install 4 rollers when you put it back together.
    I had the RIGHT to remain silent, I didn't have the ability!
    Lancaster, PA
    1,738
    On mine the front rollers wwere worn into a square,lol. Replace them like wrench said and only 4 will engage faster that way.
    1985 Tiger 250LC
    1985 Tiger 200LC
    1985 ATC 350X
    1985 ATC 200x
    1973 ATC 70 (resto project)
    and many more!!!
    Blue Line Graphics
    Aug 2003
    254
    Quote Originally Posted by smokinwrench View Post
    Thank you! That is exactly the info I was looking for. Hopefully this will fix it!
    Aug 2003
    254
    Well that was the problem for sure. What a difference that makes and hopefully they don't get turned again anytime soon. Also went with the 4 rollers as mentioned but with me on it (190lbs) it kinda seems like it slips a little. Will let it ride for a while and see how it does. Anyway Thank you for the help@
