Results 1 to 8 of 8
Thread: 250R - when tilting up, can tranny oil leak into air boot
    clong's Avatar
    clong is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2004
    386
    I was working on my new 250R last night and tilted it up (standing on end) and then after 5 mins I noticed about a tea spoons of what looked like tranny oil was leaking out of my air box. I took the air filter off and noticed oil in my air intake boot. Is this tranny oil do you think? How can it get into my air intake? The bike runs good. Seems very strange.
    1986 Honda 350X - stock w/ supertrapp, K&N, DG wheels
    1985 Honda 250R - OEM fresh trailer queen, but I'll ride it
    1985 Honda 250R - "rider" but still pretty original
    2005 Yamaha YZ250 - stock
    2007 PW50 - stock
    2005 Chevy Silverado crew cab - red, 5.3L
    clong's Avatar
    Jan 2004
    386
    Anybody?
    Is there anyway for case oil or any type of oil to flow back into the air boot and air box when tilted up?
    Could this be just air filter oil in the tube and the bike has never been tilted up till now and it drains out?
    2007 PW50 - stock
    Dec 2002
    deer park, texas
    2,336
    it is pretty normal, Tranny oil can work its way up into the top end and of course right into the intake when it is up like that. The only time i would worry is if the 250r was constantly smoking badly, then you might have a blown crank seal causing the oil to get into the motor.
    Never argue with an idiot. They will bring you down to their level and beat you with experience.
    Calling an illegal alien an undocumented immigrant is the same as calling a drug dealer an unlicensed pharmacist.
    1981 Wife ( Project)
    clong's Avatar
    Jan 2004
    386
    I hope its pretty normal. I searhed the forum for anything about oil lekaing into intake and nothing came up. The trike runs flawless and smooth with no excessive smoke so I hope it was just a non-issue event of tilting up my trike.
    2007 PW50 - stock
    Las Vegas, NV.
    2,502
    Quote Originally Posted by barry_mann View Post
    If tranny oil is working it's way into your crankcase or topend, then something is wrong, like a bad crank seal, or a leaking centercase gasket. Most likely, the oil that you're noticing is just premix that has separated from the gas.
    NE Arkansas
    2,344
    I would say (hope) it's either pre-mix or air filter oil.
    My Rags
    clong's Avatar
    Jan 2004
    386
    I guess it was just a fluke. Last night I changed the gear oil and made sure it was the correct amount. Then tilted the trike up and let it sit all evening. Not a drop of oil leaked back into the air box. I must have had a combination of air filter and pre mix oil in there and I was the first person to tip this thing up in years. She runs great and the air box is clean, so I'm running it.
    2007 PW50 - stock
    Sep 2006
    Northwest Indiana
    1,893
    Red Rider is correct. If trans fluid is entering crankcase at all, you've got problems. But as he said, more than likely is is normal separation of gas and oil which leads to a certain amount of residual oil in bottom of crankcases.
