Thread: 200s Rims
    BigRed_Ryno is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2008
    Kent UK
    311
    200s Rims
    What 9 inch wheels will fit on my '84 200s? i'm gessin like BigRed ones do, but are there any others about that would?
    Sep 2003
    Elizabethtown PA
    1,581
    suzuki quadsport 9" rear wheels are the 4x130 pattern like your 200s. big reds are 4x150 so they wont work.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
    roger86200x is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2003
    Western New York (Buffalo)
    348
    you can change your hubs and match the wheels too...
    a 200x uses 4x110 if im not mistaken. I am pretty sure my 200x hubs fit on my 200s axle....but you'll have to check to be sure...It seems like I did it before but I had another 200x that I did it with too, o I could be thinking of that too...
    on my 200x I run 9x9 rims i think they are...I know they are 9 diameter anyways...
    Roger
    1984 Honda ATC 250r
    Bored .020 over Wiseco, Answer silencer, fresh motor, New connecting rod and balanced crank, Boyesen 2 stage power reeds
    NE Arkansas
    2,344
    Yes, the hubs interchange.
    If you wanna use your 200S hubs, look for a 4/130 wheel like Jason said.
    Big Red's (250ES), have 3/6 9x9 4/110 wheels.
    My Rags
    Mar 2007
    Texas
    5,045
    what year and model suzuki quadsport?
    ________________
    https://www.mikesatvfix.com
    Sep 2003
    Elizabethtown PA
    1,581
    i knoe for sure the 85-87 lt230 models will work.
    JASON LISKEY
    2 = 86 atc 350x's
    86 atc 250r
