Sweet build!!!!!!!!!
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
Hows it coming along?
My toys 85 KXT250A2, 85 ATC250R, 85 Tri-z 250, 06 LT-R450, 04 YFZ450S, 07 125 typhoon x 3, 06 FPV GT.
Everybody is on holidays here in Greece now! So I will finish the project from september
Still haven't make the engine mounts
Now, this one is cool. Must be nice to have all those spare 86 tecates sitting around. haha
this thread gave me the inspiration to drop a newer kx 250 into mine as well! looks to be a simple build, father in law is going to be fabricating the motor mounts for me, and whatever pipe work and hangers i need. gonna be sweet having an 86 t3 with newer motor in it. and the best part is the availibility of replacement parts. sweeeeeeeeeeeet!!!
I would get a stock pipe and see how it runs... its often hard to beat the price and performance of an oem pipe... If you insist on a fmf I would get the gnarly.. These newer KX's arent known for having as strong of low-end power as previous years... and with the added weight and traction of a trike it would be much easier to ride
Just because the part #'s are different does not mean they dont interchange... they make slight changes from year to year to adjust the power delivery characteristics... its hard to go wrong... it will either be more aggressive or more mellow... either way you win.. lol...
have you figured out what you are going to use to sleeve the hole for the swingarm bolt? the Tecate uses a smaller 15mm bolt.
I have already the electronics from a 2004 kx
I will go with the fmf as I can't find here one oem used pipe and new oem and fmf here they have about the same price!
I have ordered the gnarly for better low end and a turbinecore2 silencer.
My problem now is that i can't find a lighting stator for the 05-07 engine!
Electrosport has one Lighting Stator 8-Pole for Kawasaki KX250 (02-04) - 50W but when I contacted with them they told me that it wont fit!
http://www.electrosport.com/products...etail-1983.php
they didn't told me why but I can't figure why not to work with the 2004 electronics that I have
Alex, There are comapnies here in Australia that offer aftermarket lighting kits for motocross bikes. I think that aftermarket lighting kits may be an easier way to go than trying to cross fit Kawasaki gear.
Scooteroo, Hows your conversion comming along?
cr480r, when you say older kx motors had better low down torque. What years are you refering to?
[QUOTE=OZQUAD44;641216]Alex, There are comapnies here in Australia that offer aftermarket lighting kits for motocross bikes. I think that aftermarket lighting kits may be an easier way to go than trying to cross fit Kawasaki gear.
QUOTE]
Can you give me a phone or email so I ask them if they have lighting kits for the kx 250 05-07 engine?
Or even better can you ask them for me?
No worries, give me a couple of days and I'll scout around
Back to the project with another frame this time.
And a small problem just appeared!!
I had to cut a little the frame...
love the international builds! keep on truckin!
Ray
1985 big red 250es working good. 1983 200e waiting for new crank and rod. 200x project looking needing everything.
little more progress for today
