Thread: tether switch on a 450r
    Jun 2006
    holland, ohio
    1,587
    I am puting a tether kill switch on my 450r and was wondering if anyone else has one on theirs and can tell me which wire to hook into. Thanks Rich
    Sep 2006
    Shreveport, Louisiana
    888
    I've hooked up several kill switches to modern machines and always wire them the same way...find the wire that comes off the coil and wire one side of the kill switch into that wire; ground the other wire. This setup will kill the signal to the coil, coil won't fire, bike won't run. Works great. I don't splice the harness, I make a little Y connector and plug it in to where the wire plugs into the coil. FYI, I'm not talking about the spark plug lead wire, stay away from that wire, too much power there.
    Good luck,
    Chris
    >>>>>>>>>>>>>>>2007 Yamaha Raptor 700R>>>Cross Country Racer<<<<<<<<<<<<<<
    www.myspace.com/bluelionracing
    Support my 2009 sponsor:
    For all your ATV suspension needs.
    Jun 2006
    holland, ohio
    1,587
    Thanks thats where i was headed untill i started reading the instructions and got confused.
    Sep 2006
    888
    That'll teach ya to read the instructions!!!!!!!!!!!!!
    PA
    3,515
    Quote Originally Posted by ccdhowell View Post
    Good luck,
    Chris
    this is how i always do it as well
    WWW.HREATV.COM
    Jun 2006
    holland, ohio
    1,587
    Finally got a chance to get back and finish the job, and it works. Thanks for the help. The instructiions had me tearing into the stator assembly to find the pulse wire instead of just saying the wire that attaches to the coil. Thanks again Rich
