Results 1 to 8 of 8
Thread: Head problems... HELP NEEDED!
    WaimakRydah's Avatar
    WaimakRydah is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Apr 2008
    New Zealand
    421
    Unhappy Head problems... HELP NEEDED!
    alright so my bikes been having some issues lately but managed to get it to run but sometimes it starts sometimes it doesnt... i took my spark plug off to see how black it was then i put a different one in (same size) and it was a *Edited**Edited**Edited**Edited**Edited* of a thing to get in so i forced it in by putting alot of pressure on my spark plug remover so it went in. Later i took it out and noticed i had destroyed half of the thread in the spark plug port and there was a hole heap of metal shavings around it... Is there a way i can re thread it or am I going to have to get a hole new head. I have never taken a head off before.
    1985 Honda ATC200S
    1994 Kawasaki Eliminator EL250
    Not good stuff....
    You can get a helicoil kit (about 60$) - put grease on the tap, keep the piston at BDC and have at it. Pray for the smallest amount of metal shaving contamination.
    Honestly though, if you haven't done some machinist type work, you may want to get some help.
    I'm surprised you didn't feel it cross-threading?, plugs need to thread in and out smooth so this doesn't happen.
    Back in Happy Valley
    833
    I'd say you may already have a fair amount of metal in the cyl. at this point. I'd pull the head (or motor) and find someone up to the job to get it fixed before more things get damaged. I dont know a ton about the motors so i personally wouldn't rip into one, i'd rather pay someone to fix it right the first time, TC...
    86 350X
    85 350X daily rider
    LC 250R
    85 T3
    86 T3 roller
    85 250sx beater
    Apr 2008
    New Zealand
    421
    i know someone whos dad is an engineer and he said he could take the head off and re thread it at his work for free when i took the plug out i pulled the starter rope several times in hopes of blowing metal shavings out of the cylinder thru the plug port. The plug goes in abit but it moves around abit and air escapes from around the plug as its no longer air tight. i pulled it once like this and it make a big bang... Hopefully all works out and I get the bike going sometime next week. Atleast Im not missing out on any riding because the weathers crap at the moment
    1985 Honda ATC200S
    Apr 2008
    New Zealand
    421
    when its rethreaded will i need 2 purchase a slightly bigger plug?
    1985 Honda ATC200S
    Apr 2008
    New Zealand
    421
    so my friends dad came around today and he took the engine out and he is going to take it to his place or his work. If he has a repair kit at his house he said he wont charge me but if he does it at his work there will be a charge but it shouldnt be much as it will only be for using the equipment at his work. He said it should be done by the end of the week and i should be riding by then.
    1985 Honda ATC200S
    Apr 2008
    New Zealand
    421
    Incase anyone was wondering. I got the engine back today it wasnt starting with an old plug but I got a new one and it started first pull and runs good as always.
    1985 Honda ATC200S
    Mar 2007
    Texas
    5,045
    never foirce any bolt, screw or or threaded item. it should always be a smooth transition. the onyl exception is if your using lock nuts of any type.
    ________________
    https://www.mikesatvfix.com
