hey everyone i just have a few questions about matinence on my 350x. It has a squeek somewhere in the rear, either the swingarm or the shock but i think its the swingarm. is there a way to lube the swingarm?
It needs to be all taken apart and lubed with a good waterproof grease
What weight and what kind of oil and filter do you all use?
I just run valvoline 10/w40 and use a Honda filter (if you put the filter in backwards it's bye bye topend) I change the oil OFTEN
Does anyone know where i can get bulbs for the headlight?
NAPA HM202 Bulbs or EBAY
Also are you guys clutches smooth cause mine kinda gets held up a little. could it be the clutch cable or is it the cluth itself?
Try lubing the cable, could be a notched and worn clutch basket, is neutral hard to fine while it's idling??
also my dang break fluid resiviors are shut and the philips screws are stripped out so how can i get them out to put some fluid in there? thanks for your help.
Grab a used one on EBAY or adapt another newer model resevoir to your 350X
Don't start tearing into it until you get yourself a manual or you'll cause yourself allot of headaches.
