I've always been a fan of the 85/86 250R calipers - especially the front with it's composite or plastic dual pistons.
Since then, they have made heavier racing machines and went back to a single piston caliper. Although it is larger in diameter, it doesn't seem THAT much larger enough to replace the dual setup.
Although the front caliper on the 350X and 250R is a dual piston, the 200X outdated single caliper seems just as effective? And it's near identical to the newer CR and CRF lineup calipers. It sure seems to lock up fairly easily and if you ride a newer dirtbike (although much lighter) that front tire locks up like a SOB.
I have some 250R calipers I planned on powder coating, rebuilding and installing on the 200X and 350X that I currently beat the snot out of but now I question whether it's any advantage.
I can buy a brand new 450R single piston caliper ready to bolt on for under 100$ all day long and I may just auction off all the 250R calipers I have. The parts will be available for 20 years and I won't have to buy all the special pins etc etc....
Any thoughts??
aaaaaaaaamen to that !!!!
