Thread: running rear disc on a 185s/200e?
    Mar 2007
    Texas
    5,045
    is it possible to upgrade to disc rear brakes on the 200e/185s rear drum setup? I was thinking that while i have it appart i could upgrade them, but if it's going to be a pain, i'll rebuild the drums and be done with it.
    ________________
    https://www.mikesatvfix.com
    Baltimore, MD
    6,088
    At one time there were rear disc kits available just like for the atc90/110, but nowadays they are pretty rare. If you are not a fabricator and don't have access to alot of spare parts or a machine shop, then you may just want to rebuild your drum. It is a doable project, just takes some maching and fabrication and maybe some welding depending on how you want to do it.
    Mar 2007
    Texas
    5,045
    yea i figured it woudl be a pain. i have access to all those and have my own welder, but not sure if it's worth the hastle. i'm only trail blazing not racing it.
    ________________
    PA
    3,515
    it might be easyer then you think
    on my 110 i used a 200x axle with the disc brakes. all you need to do is cut the drum brake section of the carrier off and the 200x brake hub should slide right on.
    now you probaly will need to make a spacer to locate the disc hub where you want it but other then that you just mount the master cly and your set.
    here is a link to what mine looks like
    http://www.3wheelerworldforums.com/s...ad.php?t=54324
    WWW.HREATV.COM
    Mar 2007
    Texas
    5,045
    is it worth the trouble? i wonder what the cost will be? if i'm not racing do i really need disc brakes?
    ________________
    PA
    3,515
    all i know is i never had my 110 stop like it does now....so yeah its worth it
    WWW.HREATV.COM
