Results 1 to 1 of 1
Thread: 200 m backfiring
    toronto , ont
    6
    200 m backfiring
    at idle up to 1/4 throttle roughly it backfires. can someone tell how to check the cam timing ? and what else i should try to help with the backfiring
    tonight i adjusted the cam chain tensoner and turned the a/f out a bit its just over 2 turns .
    still spits a bit when reving up 1/4 throttle.
    did a plug chop with and its lean i changed the main from 95 to a 100 cause it was showing it was lean before and it seems a little better but not very much improvement
