Thread: Gas and clutch plates, bad combo?
    Dec 2006
    W. PA
    463
    OK, I left the gas tank turned on the other day on my friend's bike, turns out the carb has a leaky needle and seat and it filled the engine with gas. But, the first thing I noticed was gas leaking from the water pump weep hole. Turns out the gas traveled from the carb, to the bottom end, into the gear box, then through the water pump oil seal. Had a half gallon of gas in the gear box.
    Now besides tearing the engine apart to fix where the gas was getting in, I'm worried about the clutch plates. Has anybody had experience with gas soaked plates? Don't want to put the engine together to find the clutches are bad, but don't want to spend the money if I don't have to either. Thanks.
    1984 250r
    heap of 200x
    POS motorcraft?
    Quote Originally Posted by JAGSFOLIFE
    THOSE F^@&ERS ARE DEATH TRAPS, BUT SO BAD @$$...
    Quote Originally Posted by yamaha gp
    trikes... DANGEROUS MOTHER F***S. BUDDY LOST HALF HIS SPLEEN AND A LIVER BECAUSE OF ONE OF THEN. HAHAH
    Quote Originally Posted by smackdab
    We decided those cute little 90 and 110 Honda 3 wheelers were what we all needed. Although our experience with those little SOB's is a story for another day, I will tell you that the Caro Community Hospital got new waiting room furniture due to those cute little devils.
    illinois
    743
    its 2 stroke?
    you got more problems than that!
    the carb will let fuel in the cylinder not the crank case!
    unless the center case gasket is bad- then it would run like crap anyway
    a 4stroke yes it could go through the carb into the case by the crank because the crank is not separate from the gear box
    a 2 stroke no
    you sure someone did'nt pull a crappy stunt on you?
    Gas won't hurt the plates at all, thats what I use to clean them when I'm rebuilding a motor...........
    Dec 2006
    W. PA
    463
    Quote Originally Posted by jason 32 View Post
    its 2 stroke?
    a 2 stroke no
    Yes, I know I got problems. That's why I'm tearing it down, either got a bad crank seal or case seal, and a bad water pump oil seal. Previous owner just rebuilt it so who knows what we'll find inside...
    Great, that's what I wanted to hear, just wanted to make sure the gas wouldn't hurt the fiber plates. Thanks.
    1984 250r
    heap of 200x
    POS motorcraft?
