Results 1 to 15 of 16
Thread: anyone buy & use this cam?
    Nov 2007
    ulysses pa
    1,231
    http://cgi.ebay.com/ebaymotors/83-85...mZ260261021492
    if so tell me what you think. almost looks to good to be true.
    It's probably an XR200 cam which bolts on an ATC 200X and does give an improvement over stock. Nothing like what a Powroll or Webcamshaft would give you though......
    ilmoakw is offline At The Back Of The Pack Arm chair racerFirst time rider
    moncton
    244
    Can you not put a 200x cam into a 200s for an improvement? If thats the case would the xr200 cam give even more improvement or would it just be overkill...
    Mar 2007
    Eagle River Ak.
    129
    I'm using one in my AutoX. Runs great. Very good power. I also installed the 10.25-1 piston and the adjustable timing gear set 2 degrees advanced. It will pull like no tomorrow.
    Danold's Avatar
    Danold is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2007
    barnesville, Ohio
    193
    I also have bought one and noticed a big improvement over stock. Lot more torqe in low to mid and great over rev.
    85 200x
    85 Tri-z
    86 Bigred
    81 Rm60
    John Deere racing tractor
    Quote Originally Posted by wad
    sorry dude mine are all shitters lol
    tbirdscott's Avatar
    tbirdscott is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2007
    Prince George B.C.
    216
    I bought one on ebay but I think it was a different seller, probably the same thing. Package said made in Japan.
    I'm just assembling the engine that its going in. I could measure it for you if you like and compare it to the stock or XR cam. I think I checked once and it actually had a bit more lift than the XRs
    Scott
    Nov 2007
    ulysses pa
    1,231
    tbirdscott, that would be great. i think i asked them once and they said .340 lift but i got no specs for duration. i think im gonna try it anyway. cant really beat the price.
    Apr 2007
    Springfield, PA
    889
    attached is the cam specs for various cams for the 200X, including the "ebay cam". i was told that the "ebay cam" is higher performance then a XR200 cam. but i am not sure if its true or not.
    Attached Thumbnails Attached Thumbnails 200X Cam Specs.pdf
    My Rides
    1983 ATC200 - U-Haul edition - great mudder - SOLD
    1984 ATC200X - sucked a valve - frame up resto & engine rebuild with performance parts in the works
    1987 Suzuki DR200
    199? Go-ped Sport
    Nov 2007
    ulysses pa
    1,231
    thanks alot 3Wheelers4Life. according to those specs it is quite a bit better than a stock 200x.
    MO dx's Avatar
    MO dx is offline Just Too Addicted Arm chair racerJust too addicted
    palmerton
    532
    When you finish the cam swap let me know how it works. The wifes auto x could use a little more down low in my opinion.
    Master of the DX and Pennsyltucky survivor ,08,09. Thats something to brag about
    Nov 2007
    ulysses pa
    1,231
    yeah mo, thats what im hopin for too! i'll be sure to get ya a ride report when finished.
    tbirdscott's Avatar
    Jun 2007
    Prince George B.C.
    216
    Finally found my calipers. My cam measures the same lift as the ebay cam posted in the pdf. Dont have the tools to measure duration, likely the same. Got mine for $35 in someones ebay store.
    Scott
    Nov 2007
    ulysses pa
    1,231
    specs are in this thread jsmay...
    Mar 2007
    Texas
    5,045
    looks like an XR cam.
    ________________
    https://www.mikesatvfix.com
    NEPA
    7,049
    I have one here somewhere Eric. The locating hole was drilled in the wrong place,I paid $15 I think. I sure will never mess with it.
