I have an ’83 atc 110, what other year 110 pipes will fit? How about the atc 90, will those fit?
2004 BMW R1150R
1972 Honda CT 70
2007 Lifan 110
If you are talking stock exhausts, that is a good question. Most 90/110 trikes I run across, the exhausts are usually so bad that I have to dig up some kind of aftermarket set up to get them working. The only major problem I would see with the stock pipe running through the frame is if the bolt holes line up on the different years with the bolt hole in your frame. I will keep an eye on this for future reference if anyone comes up with some good info.
