My 200x's engine is done (has horrible compression) so I need to rebuild it. Since I already have the engine out I want to get more power out of it (who doesn't?!?)
So my question for you:
Should I go with Option 1:
BORE KIT 198cc
66mm Piston, 10.5:1 Compression.
Designed as an overbore kit for a stock engine, or as a compliment to our stroker crank. When used with our stroker crank, this 218cc kit has excellent horsepower and impressive torque.
INCLUDES: Piston, pin, rings, circlips, head gasket and base gasket
REQUIRES: Boring, rejetting.
~~OR~~
Option 2:
BORE KIT 198cc HIGH COMPRESSION
66mm Piston, 12:1 Compression.
INCLUDES: Piston, pin, rings, circlips, head gasket and base gasket.
REQUIRES: Boring, rejetting, race gas 108 octane or greater
I WILL be buying one of these at the end of the day or tommorrow morning, so please help me decide!!!![]()
They both say they give 218 hp afterwards so what is the main difference between the two?!?![]()
More off the line power?
