First off, sorry no pics right now. both my digital cameras died. yes both!!!! stupid canon cameras. so It'll be about a month before i get pics up.
The 185s is getting a ground up restore.
completely stripped down to frame. blasted and cleaned frame.
blasting all parts and will be repainting them as well.
redoing seat completely
redoing fuel tank.
new plastics
engine: 185s bored to 200 (63mm to 65mm piston bore) wesco high compression setup.
cnc machines valve seats and ported head
web stage3 cam w/ springs
new clutches
new higher rates clutch springs
complete replacement of all seals and gaskets
rebuild and jetted carb
working on a coil upgrade (think i can get an msd unit to fit) and better plug wire
uni air filter
custom exhaust when done
nearly new tires (95% tread left for $50 the set!!! )
trike will look fairly much liek new when done and it will be done right. everything is being redone.
200E:
replaced battery
replacing coil with performance coil and wire
replacing stop/run switch
replacing all light bulbs
blasting and repainting both front and rear racks
redoing seat completely and using a 84 M seat plastic pan so no more rust!!! :bananna:
engine:
cleaned up and did a glaze brakage hone on cyclinder (stock bore)
wesco high comp piston
top end rebuild kit
cnc valve job and ported head
stock cam and springs for now. (in 3-4 months will upgrade to web stage3 cam and spring set)
when i get a weisco piston i always get the complete kit with the head setup as well. that means the good HG and seals not the crapper ones.
as soon as i get a new camera (gonna get me a 13.6 mega pixle one for like $250 yea!! ) I'll post pics. my phoen takes the crappiest photos so no go there.
I should have the 200E running with in the next 3 weeks.
