Other than the rear brakes what are the differences? Is the carb, jetting, reeds, pipe and specs the same?
It's a celebration bitches!!!
Mainly the 81 has a rear drum brake and the 82 has a rear disc brake. I know the 81 has 3 bolt rims and I think the 82 has 4 bolt rims so the front and rear hubs will be different.
The frame, swingarm, front rotor, hubs, wheels, airbox, handle bar switches and controls are different from 81-82. The frame and swingarm because of the disc brake rear, front rotor is drilled on an 82, airbox sucks through the frame instead of under the seat.
Lots O Trikes!!!!!
TRIKEFEST 03, 04, 05, 07, 09 Going the distance
The rear fender is slightly different as well because of the airbox under the seat
