Results 1 to 9 of 9
Thread: atc200s carb bowl gasket question...
    MonkOFox's Avatar
    MonkOFox is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jul 2008
    texas
    264
    I got a rebuild kit for my atc200s and the gasket between the top of the carb and the bowl was just round not pre-bent, and it was a little to big also. Could I just cut the gasket and butt it up and just put a lil silicon on it to hold it in?
    I can't find that gasket anywhere by itself, and I refuse to buy a full gasket kit for 20 some odd dollars.
    Thanks,
    Justin
    Tionesta, PA
    5,747
    Those 200s bowl gaskets can be a ROYAL PAIN~! I know - I was in your same situation. I simply made a permatex seal - and let it set up for about 6 or 8 hours before I put gas in it - no problems afterwards. The only thing that sux is the next time you tear apart the carb - you gotta scrape off the old - and redo it again.
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Sweet, so I can just use any old silicon gasket maker huh?
    Thanks,
    Justin
    cybrman's Avatar
    cybrman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Winter Park, Florida
    254
    Not sure how "too big" your gasket is but if it's close...
    I've had success in the past using a bit of grease to keep the gaskets from popping up out of the groove because they were a tad too big or stretched out a bit.
    1985 250SX #2 300sx risen from the ashes.
    1985 200X
    1983 200
    1979 ATC70
    1985 ATC70
    1985 ATC110
    1985 Big Red
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    Naw, this one is about half an inch too long. Also, How do you adjust the float to where it will shut off the valve sooner I guess. My float pin is bent a little bit and I think is jamming everynow and then causing the bowl to leak (i'm sure its not the drain screw).
    Thanks,
    Justin
    Tionesta, PA
    5,747
    I would not suggest "any old silicon gasket maker" - it must be "gasoline proof"
    MonkOFox's Avatar
    Jul 2008
    texas
    264
    do you just get your permatex stuff from autozone or what?
    1985 200S - fixer upper
    Nov 2002
    Kirkville, NY
    3,831
    Yes make sure it us gasoline safe (many are not!).
    It is difficult to fit a new 0-ring in the odd shaped bowl gasket surface, what brand carb kit do you have? I have used a few of those kits in the 200 series trikes and haven’t had a problem, granted that gasket I only replace if it is leaking. I use a very very small dab of super glue around the bole to hold the o-ring in place as I work it around and install the bowl.
    2004 BMW R1150R
    1972 Honda CT 70
    2007 Lifan 110
    Mar 2008
    florida
    70
    I thought the same thing when I got my carb kit. It took me about ten minutes to get it right. I put a small amount of greast in the channel where the oring goes in order to keep it there as I worked it around the corners. You must take your time and make sure you dont stretch it out. Trust me, I was so mad when I opened up the package and saw a round oring, however it is the correct one and WILL work if you just take it slow.
