Results 1 to 12 of 12
Thread: some yami yt ?'s
    Nov 2007
    ulysses pa
    1,231
    some yami yt ?'s
    startin to put together my yt. got a few ?'s
    1. will the stock exhaust from the 175 work on the 125?
    2. on the fuel tank cover there are 2 lower mounting holes. well, what appear to be mounting holes. is there some sort of bracket that they mount to? both of mine have nothing in this area. im thinking i may be missing something.
    3. oil tank is off and all lines are plugged. is 32/1 gas/oil mix a good place to start?
    May 2008
    Juneau
    605
    1. yes it is a direct swap, the pipes are different but fit the same
    2. sounds wierd what yt is it off of the 125 or 175 you could be missing it
    3. i run 40:1 and ive been told that its to rich but my yt runes great and i mix yamalube injecter/premix race oil with unleaded gas
    3 wheelaholic
    ATC200/CR480 custom
    1984 atc250r near mint
    wr450f trike on the way
    Trizinger for my sons
    Nov 2007
    ulysses pa
    1,231
    thanks trimotoman.... i have the 175 front end on the 125. everything else is 125. im sure there is some kind of mounting brkt missing. i just dont know what it looks like.
    May 2008
    Juneau
    605
    Well this is what my frame looks like, on the front of the frame there is two mounting brackets but it only mounts to one and then in the back there is one
    Attached Thumbnails Attached Thumbnails frame1.jpg   frame2.jpg   frame3.jpg   frame4.jpg
    3 wheelaholic
    ATC200/CR480 custom
    saladboy's Avatar
    saladboy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2006
    michigan
    181
    125
    here is my yt 125
    May 2008
    Juneau
    605
    nice is it all stock?, my yt is except for tires and my front hub, axle, and rim is off an atc 110
    3 wheelaholic
    ATC200/CR480 custom
    saladboy's Avatar
    Oct 2006
    michigan
    181
    yep all stock
    Nov 2007
    ulysses pa
    1,231
    trimotoman, thanks for those pics. i think i found the missing brkt in a box of xtra parts that came with it.
    saladboy, looks to be in real nice condition. wish mine looked like that. i got a couple pics of mine in edogs trimoto thread.
    mine is an 82 125 with an 83 175 front end. quite the pile i got it for $100.00. but it looks like i'll be able to get 1 running bike. i'll get some pics of it after i get the plastic cleaned.
    May 2008
    Juneau
    605
    It wont take much to get it nice, even a pile can be a hell of alot of fun. i put $3000 in to my yt but i ride it more then i do my blaster
    3 wheelaholic
    ATC200/CR480 custom
    Baltimore, MD
    6,088
    Finally got the yt175 over to my house and took a couple of pics. Not much to look at right now, but it was a deal when I got it. I've put on a bunch of new parts and have lots more to install besides the pro-tec kit I have. I will add some more bits and take some more pics. I'll probably tear it back apart soon to paint of pc the frame. I just managed to pick up something else and not sure what I'm going to do, but maybe an engine transplant shortly!!! I hope to have some more time to do some work on it this coming week. I might edog the frame for the temporary just to have it look a little better. I've got to finish recovering the seat for it too. Anyone have a really nice or nos set of rear fenders or fuel tank cover????
    Attached Thumbnails Attached Thumbnails tmpphpkB62qY.jpg   tmpphpnGEhgI.jpg   tmpphpob1Fpa.jpg   tmpphpZsy90H.jpg
    Nov 2007
    ulysses pa
    1,231
    wanted to say that the pipe of an 83 175 is not a direct bolt on to the 82 125. the 125 pipe has an attached flange and the 175 is a seperate flange. thats not the problem though, the rear mount on the 125 pipe and the 175 pipe are different. i think this will be an easy fix but just wanted to note that a brkt will have to be made. other than that it will fit and also want to note that the front brkt will bolt up. only the rear will be a problem. when i get this fixed i will take a pic to show what i mean.
    Nov 2007
    ulysses pa
    1,231
    since im here, i got my tri-pile running, like crap but running, takes 1/4 throttle well but anything else and she is a dog. been through the carb quickly, dont think its there, possibly a problem with the choke plunger. not sure yet.
