Results 1 to 3 of 3
Thread: 84 tri moto 125
    Jul 2008
    NY USA
    3
    84 tri moto 125
    Im new on here and just picked up a tri moto 125 just got some ?... what is the line that comes out of the base of the cyl. that is spewing oil and gas all over when riding.. and also i am thinking of unhooking the oil inj and just premixing what would you recomend i use for oil and what ratio... when reving up it boggs for a split second then will rev.. why is it doing this and how can i fix it...
    saladboy's Avatar
    saladboy is offline At The Back Of The Pack Arm chair racerFirst time rider
    Oct 2006
    michigan
    181
    i would clean out he carb frist.i run 32:1 in mine.if you disconnect the oil injection you have to block off the oil pump.not sure about the oil spewing line.maybe the line from the oil pump to the carb is off.
    May 2008
    Juneau
    605
    I run 40:1
    3 wheelaholic
    ATC200/CR480 custom
    1984 atc250r near mint
    wr450f trike on the way
    Trizinger for my sons
