I've been plugging away at adding a ytm200 front end to the yt175. It's been a little work and I had to change the original idea a little, but it's finally on the trike. Originally I had to machine the stem out of a set of ytm200 triples and machine away the unwanted lower triple off of the yt175 stem. I made a spacer to try and shim the ytm200 lower triple to the same height as the lower perch where the yt175 stem is, but later found out that I didn't need that at all. I machined the stem nut around 1/2 of it's normal thickness and bolted on the lower triple tree. The steering stops work perfectly. I sort of got lucky where I tig welded the yt175 stem into the ytm200 lower triple. Then I drilled out the stem hole on the upper ytm200 triple tree to 1" which allowed the ytm200 upper triple to barely slide over the yt175 upper stem. Insted of using the yt175 cap nut, I used a bolt that was pretty much the entire length of the yt175 stem, 8" if I remember right. I drilled out 2 flat washers to have an interference fit to the bolt I used so they would be nice and snug and then I sort of cobble together a piece that was made from 2 bolts welded together and the lower bolt sort of cone shaped so it would fit up into the bottom of the lower triple tree, all nice and hidden. Now the bolt that passes through the stem screws into the assembly that goes into the bottom of the lower triple and it ties the whole thing together nice and secure. I'll see how this works and it just might be the final design that I'm going with. There is also a bronze busing that is pressed into the upper part of the stem and drilled so it will let the bolt pass through but keep it from moving around. I don't know if this is the best design, but it was just what I cam up with hashing an idea around with my machinist buddy at work. There may have been a more elagant way to do it, but this seems to work well. Here are a few pics of the triples installed on the yt frame.
Nicholson 500x (Project)
Nicholson 185s
PK Racing Suspension 70
A+ Inc Suspension 70
AWS Aluminum 90 frame
