Results 1 to 8 of 8
Thread: no fire
    Oct 2007
    corinth ms.
    77
    no fire
    hey guys, I am working on my uncle's honda 250 es.He said that when he bought it the guy cranked it and it run good, loaded in the truck and brought it home. Said it would not start. there is no fire. So where is the best place to start looking for the problem? thanks Joe
    Mar 2005
    Underwood North Dakota Tiger country
    1,055
    check all your wire connections I have had 2 of these do the same thing and it was a bad connection. also if the starter won't work check the reverse/neutral wire on the bottom of the motor under the kicker
    Trikes currently owned
    E.T. trike 150H.P. and climbing Pure DRAG beast
    85 250r project
    Oct 2007
    corinth ms.
    77
    no fire
    it turns over fine, just no fire
    Des Moines, IA
    1,303
    You have to check for spark....have you done that yet?
    God knows they're not looking to make any effort to do anything, never mind move their foot to shift. If there was something that dispensed Cheetos every time they shifted that might be a different story. Welcome to America, where the biggest is best and even fat people who are too lazy to shift can climb a mountain.
    Mar 2005
    overton, PA
    5,257
    down on the engine case on the kicker sid ethere is 2 wires that connect to the motor behind a small guard down along the frame rail make shure thie rboth have good conections if the neutral safety switch is not conected it willnot get any spark check and double check this conection its the only thign that has made my sx and big reds stop int he past.
    Oct 2007
    corinth ms.
    77
    thanks guys
    will do, thanks
    Oct 2007
    corinth ms.
    77
    still no fire
    check the 2 wires at the bottom of motor, hooked up good, sprayed with contact cleaner. I guess my next move is a new coil....... thanks guys
    May 2008
    Northwestern Ontario, Canada
    552
    Test your coil with a ohmmeter first, those things (coils) are not that cheap and I'm always worried about what you wind up with from e-bay. Not sure what the readings are suppose to be on that one, somebody with a manual can probably chime in. Also check that the spark plug cap is well seated and twisted into the plug wire, they sometimes work loose.
    Check all the wires starting at the alternator wires with a voltmeter and work you're way out from there, testing at each wire termination/connector.
    Coils are hard things to kill and if it ran just before you brought it home I'm guessing like the guys above that the wiring somewhere got loose.
