Results 1 to 13 of 13
Thread: 20:1 Gasoline - oil mix
    Canada
    185
    is it to rich.
    i read a lot of post with people that said they run 32:1.
    ALP
    Beav
    When there's a place to Jump, there's always a place to land. Don't matter if it's hard or not. Gotta find the limits of your trike.
    1984 250r
    Mods : Uni filter, 36mm Flatside Carb, Boyseen Reeds, P&P with a little bit of port timing (more to come), High Comp. Head, DG Full Exhaust.
    1986 250R
    Just got it give me some time to mod it
    bentwrench is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2003
    204
    What are you useing this mix in??
    84250r is offline Clean enough to eat a potpie off of Teaching quads a lesson
    Michigan
    2,718
    Go to www.denniskirk.com they have some good 2 stroke oils. Like Koltz. I would mix it to 32:1. Seems to be more popular.
    R.I.P Raven
    2006 Yamaha Banshee Special Edition
    1996 Honda CBR 600 F3
    Dec 2002
    Kansas
    2,387
    I run Honda HP2 oil at 42/1 mix.
    Josh
    I had the RIGHT to remain silent, I didn't have the ability!
    Apr 2003
    204
    He shows owning a 250SX and a 200ES and he's wanting a 2 cycle mix? I missed something I guess.
    Dec 2002
    Kansas
    2,387
    He has a blown up air cooler R it is listed in another post somewhere.
    Josh
    Canada
    185
    yeah exact a blown up air cooled air 250r. sorry forgot to change my sign ans avatar. got the trike last saturday.
    why do they wrote this on the tank then. 20:1
    ALP
    Beav
    1984 250r
    1986 250R
    Michigan
    2,718
    Well back in the 80's oil wasnt as good as todays oil. Time has changed. Ayone else want to add to this?
    R.I.P Raven
    oil
    i'll add_____ SYNTHETIC!!!!!!
    Canada
    185
    ok so i can mix 32:1 without any pro with esso two stroke oil that can mix up to 100 :1
    ALP
    Beav
    1984 250r
    1986 250R
    Nov 2002
    1,189
    yeah, 32:1 seems to be most versatile on everything.... and yeah, oils today are a lot better.... and i wouldn't recommend running 100:1, its only for speed freaks who like to ruin their engine.... with any oil it can't be good.
    My Rides
    Yamaha 225 DR For Sale Soon
    Yamaha 200E
    Honda 110 Need parts? PM me! They're cheap!
    Trikes are fun, trikes are fast. They make everyday a pure blast!
    bbechtel16 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Halifax, PA
    400
    Amsoil 50:1 racing style! :-D
    -'86 ATC 250SX: No longer mine... Complete 350X front end, Corbra Megaphone system, 350X carb with UNI dual stage foam & outerwear bolted driectly up, Powroll/Rocky 260cc bore 10.5 to 1 compression piston.
    Feb 2003
    485
    Blue Marble 50:1 is all you will ever need. If the motor is fresh you will be good to go. If you make the switch on a top end with time, expect to foul a few plugs in the first few tanks. This is because the BM oil cleans the carbon deposits and you will notice when pulling the fouled plug that it is covered with a goooey black substance. After 4 tanks or so the new power and next to no smoke will make you a beleiver. This is the 2 stroke oil of the future!!!!! I have yet to venture leaner than 50:1, but I have read about great sucess at higher ratio's. My 250R, Blaster, weed whacker, chain saws, etc love the stuff. Less vibration to!! :-D
    Todays oil is not even in the same class as the oil that was used in the days they made that 20:1 label.
